WOW! NEW ECU FLASH
Old Nov 11, 2008 | 04:13 AM
rarfinancial's Avatar
CLS63
WOW! NEW ECU FLASH
If any of you have the old ECU tune from the dealer (2007 63's) I recommened getting the Dealer to flash it. My car always started in second gear unless I put it in first myself. The car feels like a new car and the trans starts in first every time The shifts switch much later in sports mode and down shifts great. Also when on the freeway if you give it a little push on the gas it will shift down a gear and if you push a little harder it will go down two or three gears. DO THE NEW FLASH Like I said the car shifts like it has a modified TCU Tune no Idea way but it kicks butt over the crappy 2nd gear start
Old Nov 11, 2008 | 11:57 AM
blackcls63's Avatar
07 CLS63 | 06 SLK350
is it a TSB or something you have to pay $$ for ?
Old Nov 11, 2008 | 12:43 PM
HAHA BYE's Avatar
2003 E55 Blk/Blk
does the e55 start in second?? I thought that was only in like some snow setting or something
Old Nov 11, 2008 | 01:18 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Here you go
Old Nov 11, 2008 | 02:05 PM
phatmitzu's Avatar
2005 E55
Originally Posted by James@ACGSD
Here you go
Old Nov 11, 2008 | 06:18 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Never heard the final chapter concerning your ECU/battery problem. I take it that you resolved that issue.
Old Nov 13, 2008 | 05:38 AM
sterlingc1975's Avatar
2009 Porsche turbo, 2011 Porsche gt3(Luv) 2008 clk black- RIP 2003 Honda Element (Fav)
I agree with this 110%.. My car was always starting in 2nd. Sometimes it seemed if the idel would fluxuate like it didnt know what gear to go into.. I took it in for this prob and some hesitation issue. My SA adivised me that it was a bad intake manifold gasket and they put a new one on and bolts and reflashed ecu and tcu software and it runs completly different even better Now from when I first purchased the car. I have better throttle response and shift points seem to be higher in the revs as well.. much better
Old Nov 15, 2008 | 03:34 AM
CLS63
That's right , same here. Yes, my problem is solved. Once James reflashed my old ECU with the Renntech tune all was fine. I had already ordered a new ECU so I had it coded and installed it. I am awaiting yet another ECU and will code that one also, then let the tuning begin
Old Feb 19, 2010 | 01:11 PM
Dericious's Avatar
CLS63
Has anyone in LA gotten a dealer to do this? My car still starts in 2nd in S unless i floor it. Then the next time i come to a stop, it'll go to 1st.
The dealer and MBUSA both keep telling me this is normal.
Old Feb 19, 2010 | 04:09 PM
iamnsxtc's Avatar
NSX, CLS63 AMG (030), CBR600.
This is not normal. I just had my done for the same reason and for a very hard 3-4 upshift....with the reflash in S mode it starts in 1st no matter what.
They said that is was the program. Car runs pretty damn good now.
Old Feb 19, 2010 | 04:12 PM
M-bENZ's Avatar
Corrolla
oh so its free at the dealer or you have to pay ?
Andy
Old Feb 19, 2010 | 04:16 PM
Dericious's Avatar
CLS63
If anyone can provide me a dealer and SA that knows the issue and can take care of it. Sick of arguing with my local dealer about it. PM or post would be appreciated.
Old Feb 22, 2010 | 09:04 AM
iamnsxtc's Avatar
Andy
Hi Andy,
It was free. I just bought this car and it was still under the factory warranty. I bought it from Tampa and brought it home to Charleston. So I wanted the car to start a history with this dealership. Everything they did was no cost..
Old Feb 22, 2010 | 09:06 AM
iamnsxtc's Avatar
I have a membership with alldata.com. I can try and forward you the number later today. There is a service compaign that directly explains the problem and the fix.
Old Feb 22, 2010 | 09:48 AM
Roverron's Avatar
ML63
is this update only for 63's
Old Feb 22, 2010 | 07:51 PM
iamnsxtc's Avatar
hope this helps... this is what I had This is from alldata.com:
A/T - Hard 1-2 Shift/Hard Converter Lock-Up
Date: December 4, 2008
Order No.: S-B-27.00/112
Supersedes:
Group: 27
SUBJECT:
All Model Vehicles Equipped with 722.9 Transmission- 7G-Tronic (NAG2)
Hard 1-2 Shift and/or Hard Torque Converter Lockup Clutch Engagement
If you receive customer reports in the above model vehicles of hard 1-2 shifts, the condition may be a hard KUB (torque converter lockup clutch) engagement during the start-off procedure.
To determine a clear diagnosis, investigate the complaint with DAS and observe the state of the KUB. If a jolt occurs when the KUB switches from "Open" to "Slipping", the cause may be in the control system of the KUB. Perform the following to resolve.
1. Update transmission software via DAS 10/08 or later, menu item "Initial startup" followed by SCN coding.
2. Adapt the KUB by coolant temperature and torque window via DAS menu item "KUB adaptation". (Use the following password until DAS DVD 11/08 is released: 48998)
NOTE: The following allowable labor operations should be used when submitting a warranty claim for this repair. This information has been generated on December 4, 2008. Please refer to Netstar -> Star TekInfo -> Star Time for the most current labor time allowance.
In Case of Warranty
Operation: Short test perform (54-1011)
Control unit - software (after short test), install (54-0991)
Control unit - code (after short test), perform (54-0992)
Adaptation, perform (07-1047)
Road test, perform (00-9151)
Old Feb 23, 2010 | 08:55 AM
joeybenz106's Avatar
2007 cls 550
Does this update give you the throttle blip when down shifting like on the 2010?
Old Feb 23, 2010 | 10:00 AM
RAW INC's Avatar
cls63
I also had this done at the dealer when they replaced the manifold gasket. But does anyone else feels like its less torque in those gears. maybe its just my imagination but i dont get that sink in the seat feelin as much
Old Feb 23, 2010 | 02:44 PM
Dericious's Avatar
CLS63
Thanks! I'll try printing this out and going in to ask them to do this. I can't imagine they would say no to getting to bill MB for some work....
Old Feb 24, 2010 | 11:18 AM
iamnsxtc's Avatar
NP I also had a hard 5th to 4th downshift and the new program cleaned it up.
Old Mar 12, 2010 | 01:45 PM
Dericious's Avatar
CLS63
I has this update down and now i have the jerkiness issue described in another thread:
https://mbworld.org/forums/cls55-amg...-lease-up.html
Old Mar 17, 2011 | 11:05 PM
Jan Rosenberg's Avatar
I do not own a Mercedes
I've tried to get this KUB adaptation done on a transmission that was just rebuilt, at two dealers. Both have lied and said they did it, but when I asked for the conformation page saying the adaptation was completed sucsessfully, the could not produce it, and then said they tried to do it but could not get it to work. ????????? Any suggestions. What is the mystery about this procedure.
Jan Rosenberg
Old Apr 17, 2013 | 02:39 AM
ken_e63amg's Avatar
w211 E63 AMG
Id like to know this as well
Old Apr 21, 2013 | 11:24 AM
tommy350's Avatar
06' Lexus IS350
Nice! I don't know why I didn't see this on the fourms before!
I've been holding back on doing a ecu reflash for a little while now, and I wanted to know. Does this dealership reflash give any gains? Does anyone know if a aftermarket ecu reflash fixes these gear problems? I never really noticed my car starting at 2nd haha my cluster is always on the radio when I drive it :\
Old Apr 30, 2013 | 10:33 AM
juicee63's Avatar
2011 twin turboed prius
Make sure you have all the updates installed. This should solve it. If not get a tune it will change shift points to your desire and raise the limiter on non PP cars.
