Spontaneous wind flapping sound in cabin
Subscribe
Dec 21, 2008 | 11:50 PM
Every once in a while regardless of speed, I can start to hear a lound wind flapping sound inside the cabin. Its the same soud as when you only have two windows open. I have no idea what it could be and is starting to drive me nuts. I haven't taken it to the dealer yet because of the spontaneous nature of the sound and not being able to reproduce on command. Has anyone else experienced something similar?
Reply 0
Feb 10, 2009 | 06:21 PM
Quote: Every once in a while regardless of speed, I can start to hear a lound wind flapping sound inside the cabin. Its the same soud as when you only have two windows open. I have no idea what it could be and is starting to drive me nuts. I haven't taken it to the dealer yet because of the spontaneous nature of the sound and not being able to reproduce on command. Has anyone else experienced something similar?
Well I figured maybe that sound could be related to tires, but I just had a set of tires installed recently and same problem. I only tend to notice it on the highway, especially if its windy. Its noticeable enough to make your head hurt if you listen to it for a while with the radio off.
Reply 0
Feb 10, 2009 | 07:26 PM
I think the noise your describing is produced as a result of differential air pressure in the cabin from the open window (s).
To resolve the problem readjust window opening slightly or open or close a 2nd window. If the noise disappears, you solved the mystery.
Reply 0
Feb 11, 2009 | 02:46 AM
Could be bad weatherstripping?
Reply 0
Feb 11, 2009 | 01:14 PM
Quote: I think the noise your describing is produced as a result of differential air pressure in the cabin from the open window (s).
I wish it were that easy. All windows/sunroof are closed.
Reply 0
Feb 11, 2009 | 01:32 PM
Wash your car and see if any wet spots develop.
Reply 0
Subscribe
Currently Active Users (1)
