cls55 tire pressure system...how do i?
Old Mar 22, 2009 | 10:32 PM
rbtronnie5's Avatar
You name it i've had it or got it...
how do i turn it off using the dash? i switched my wheels on my car....last set had no issues but new ones for some reason cause the dash to read "tire pressure"....i used to know how to do it using the buttons on the steering wheel, but now i can't remember!!! help me!! walk me trough it...thanks in advance..
Old Mar 23, 2009 | 06:10 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
hi, hope this helps
I don't have my car now so can't say anything more to help
Old Mar 23, 2009 | 05:59 PM
rbtronnie5's Avatar
dyno...i dont have the active tire pressure system...i only have the basic one that senses if i have a flat or if the ecu reads that one of the wheels is not rotating in sequence with the others....
Old Mar 23, 2009 | 06:40 PM
dyno's Avatar
therefore it's a bit strange, as either new wheels do not have any sensor inside and I would think that you have inflated them equally ..
I would go to the screen showing the tire pressure function and then, try to push the reset button
