Removing the Engine cover
See the picture, it is the area in red.
also its 2 parts just incase u are confused the top half is the air box, the part wit the mb star is just a front enine cover (what you want to remove i guess)
If you need the torque spec ... you can just use the torque wrench to remove the bolts. Watch the number at which they break free. It's usually within 10% of the right number (Which would usually be lower)
If you can't get the spec ... that's usually a very safe bet.
