LED city lights and license plate bulbs (no errors)
Flying Spur
thats weird because im 100% sure we got the exact same bulbs...did you try flipping them? I know when i put them directly in to the plastic casing they didnt work, they barely fit in there. Then i tried putting them directly into the socket and i remember they didnt work the first few times...i tried again and they worked...so i left them in the socket, cut the plastic piece that holds them in place to it would just slide in...give it another shot im sure they'll work
Brand New to Mods
Ok Need some help here.....I went through this thread and I am very interested in replacing some bulbs on my car but have not attempted this. Is it easy to do? I have the CLS 55 AMG and just got it. I would like to replace the license plate lights and need advice on what else makes sense in the front.
I got the city lights from ebay (below link) and they work perfectly. Ed at HMS put them in for me, took some force but he got them in there after a couple of mins.
License plate bulbs
http://cgi.ebay.com/ebaymotors/ws/eB...ht_2871wt_1318
City light bulbs
http://cgi.ebay.com/ebaymotors/White...ht_6679wt_1318
Good luck.
License plate bulbs
City light bulbs
Good luck.
Try these:
City Lights
http://cgi.ebay.com/ebaymotors/ws/eB...0216&viewitem=
License
http://cgi.ebay.com/ebaymotors/White...item5883636601
City Lights
License
2003 S600, 1988 RX-7 single turbo vert, 1998 BMW 740IL
Great upgrade guys. I will attempt this shorty.
I also can understand the hit or miss approach when it comes to lights from ebay. I bought led blinkers for my 7 series and they had to be cut just to fit inside the back of the tail light.
Suraj
Flying Spur
Could you post a pic I tried to do it on my car today with no luck. I just checked the thread and it does make sense, but I want to know what I am going to do before I attempt something I might regret. Also on the plate lights, I tried to unscrew the casing for the lights but they won't come out should I open the whole trunk cover to reach them?
Flying Spur
ok here's the DIY
The Bulbs
1.Remove the two screws on the plastic thing that hold the bulbs
Once removed, the bulb should be attached to the plastic holder, take the bulb out of that
2.Cut the plastic holder so that it looks like the picture below (i used wire cutters
Dont worry the stock bulb will still work without it being mounted in the plastic holder
3.Put the LED bulb in the socket, it is directional and may take a second to light up
4.Place the plastic cover back in and screw it
5.Repeat on the other side
Took me 10 minutes tops
Hope that clarified things for everyone
The Bulbs
Thank you for the pictures
I got that part done and it looks great!!!
And if it wont be too much trouble could you also post pictures of your front parking lights. I am stll having problems with installing those
I nstalled the licence plate lights too they work perfect. could you please post pictures of how to take out the city lights? having problems removing the lights!
Flying Spur
Flying Spur
Thank you again, it worked! I shaved the sides where they go into the socket with a pocket knife, finally they went in, they didnt turn on right away I moved it around a little and they work now!!! lots of cuts and scrapes on my hands but it paid off, they look great
Flying Spur
