Need help with Wheel Offset
Old Oct 24, 2009 | 11:50 PM
misterTRIGGER's Avatar
CLS 500
Can anyone tell me what offsets would work on my CLS for a 19x9 wheel? Thansk for any help!
Old Oct 25, 2009 | 12:29 AM
juicee63's Avatar
2011 twin turboed prius
O n the CLS 500 you can use 20-35mm w/o spacers maybe even as high as 38.
On a non staggered set up 25-32 all the way around, staggered fronts should be 25-32mm rear 28-35mm
Old Oct 25, 2009 | 12:39 AM
CLS 500
Thanks for the respones, just 1 more question so 39mm all around in a nonstaggered setup would not fit or would rub? ahah Also would it possibly work if i got spacers for it?
Old Oct 25, 2009 | 12:47 AM
juicee63's Avatar
as long as you have stock brakes and not brembo or amg calipers the fronts should clear rears will fit .
You likely would be fine , see how it looks and if not tucked nicely just add a spacer, very easy to do and not expensive.
Old Oct 25, 2009 | 09:05 AM
Full Throttle's Avatar
CLS55 AMG
Go with 20's you will regret it if you don't later.
Old Oct 25, 2009 | 09:32 AM
spookie22's Avatar
cls63
For the 20's, are the offsets the same as above (I have the big calipers from the amg performance package)?
Old Oct 25, 2009 | 11:37 AM
jangy's Avatar
2015 S212
Offset shouldn't matter on wheel size, especially if you are keeping the rolling diameter the same.
20s SUCK!!!! That's 75% of the reason why E55s handle better.
Old Oct 25, 2009 | 02:55 PM
juicee63's Avatar
The look great but they do suck performance wise. 19 is fine especially on a 500. If you are going for looks a 20 does look better on the CLS
Old Oct 25, 2009 | 08:08 PM
SL2003driver's Avatar
CLS63, GLK350
Will someone say bent rims
