How do you remove the instrument cluster?
I'm usually pretty good with this stuff, and rarely need to look up such "how too's" but in this case, I don't want to miss a special procedure, clip, screw, or something in that nature and end up breaking things...
No one locally has a service manual in stock I can purchase, so I wanted to see if anyone here had any experience in doing so.
Any help, advice and or suggestion would be greatly appreciated!
Lower your steering wheel column and pull it all the way out so you have more room to play with. Take your thumbs and place them underneath the chrome trim that runs around the cluster, pry it up and it should unclip, don't be afraid it's not that easy to break, and it's pretty flexible (sometimes I unclip it on the move since it's a great stash spot
) one you got the bottom part out, work your way around to the top and slide the trim out. You'll find 4 T25 screws holding the cluster in place, take them off... then remove the plastic pin that you control the backlight with. From there on, pull the cluster forward, and face it down so you can unplug the harness, push the little arm clip thing down and flip it to the left, it'll lift the whole harness off the cluster and it should be free to pull out.
