Light Weight Battery From Braille
I would stay with the 15 lb version for the CLS
Since the weight is not equal over both rear tires it would likely not be "heavy" to balance the car.
The heavy battery in some cases has provided better traction and the weight reduction is negated.
Rotational weight makes a more significant difference but saving 50-60 lbs just by a swap of a battery is worth nearly a tenth.
Had I been using a Braille or Voltphreaks battery at the last event in Sacramento the car hits 11.xxxx instead of 12.000.
I chose not to run it because they have failed me on the track in the past in terms of cranking amps and reserve power. The stock battery is stout in those characteristics.
When running a light battery you must make certain your bluetooth, ipod, radio, command, key less go , are OFF and not pulling any reserve. Having the battery die can cause a plethora of problems.
For starting our car about 600-800 cranking amps are enough (a smaller V6 engine needs a bit less, obviously) and even a battery with low current storage capability can afford starting it, provided it has cells with high discharge rate able to produce the cranck amps required (as that Braille seems to have) and provided the engine will start immediately .. you will not be given a lot of chances !
but even a lot of crank amps cannot be traded with and do NOT replace lack in current torage: the stock 95Ah of current storage are hardly enough for playing a dvd in your car for more than 20minutes at medium volume, provided nothing else is running.
You could get the same result with one third weight if using for example a 70Ah Voltphreaks Lithium battery (just because Lithium batteries are more efficient than Lead acid batteries at delivering current under high load, but it will also not last longer than 20 mins).
Last, just take into account that
- airmatic draws 40Amps and the radiator fan needs ...150 !
so, if you need the car for normal use I strongly recommend not doing it.
If you just love lightweight things and don't want any worst performance than you have today, then, no choice than going with Lithium
(with no less than 50Ah) but that is .. mucho dinero
you see, I am playing with electrics just to avoid thinking at that.
but, I 'm learning .. I'm learning ...
maybe one day ..
ps:
where are you from ?
to the op also remember the temps in the area you live the colder the area the less cranking time you will have. cold cranking ampos are what to look for. (cca)
nope ...I was in contact with Jerry exactly one year ago and there was nothing he could do .
further, I am no more very willing to waste my time !
I have the $150 Braille 17-lb battery and it works fine. It tends to lose charge faster than a full size but that was expected.
good find
... the Deka website has the exact replacement battery for our cars.
to the OP:
don't be fooled by simply reading CCA values.
pay attention if they are "pulse". ... pulse means a duration extremely short (from .2 to 5seconds usually), while the reference test is for 30seconds.
so, just as a reference, 1000 pulse is worth less than half standard.
