LIMITED TIME! Evosport Performance Rotors...Save $400!
Now through March 1st, we are offering our best-selling E/CLS/SL55 AMG Kompressor OE brake rotor replacements for $1,599 (that's $400 off the $1,999 price!). Shave over 34-LBS unsprung weight!
We haven't offered any deals like this on these since 2006!
Designed as a direct brake rotor replacement (front and rear) for the OE W211 E55, W219 CLS55 and R230 SL55 (rear only for 030 Package vehicles) AMG Kompressor brake rotors. No modifications are necessary. The rotors are designed to bolt directly to the OE AMG calipers. Not only will the upgraded multi-piece "floating" rotors help mitigate brake fade, but are lighter than stock and reduce unsprung weight by a total of 34-lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Ask us about available brake pad options for this setup as well.
Benefits:
Discs are available in:
Drilled/Slotted Design:
![](http://www.evosport.com/images/product/brakes/evosport/es-e55brake-ds2.jpg)
![](http://www.evosport.com/images/product/brakes/evosport/es-e55brake-ds1.jpg)
Slotted Design:
Benefits:
- Lightweight multi-piece design using hard anodized aluminum hat offers huge weight savings over heavy OE one-piece rotors (over 35-lbs unsprung weight!)
- Unlike OE rotors, which vent the wrong way on one side, our rotors are designed for proper Left/Right application for maximum venting/cooling
- Easily installs with no modifications using OE brake calipers
- Functional upgrade you can feel! Results in improved acceleration, braking and cornering
- Floating design helps dissipate brake fade for street or track use
- Replaceable discs so you don't need to purchase entire rotor
- 2-year warranty on hardware
Slotted Design:
![](http://www.evosport.com/images/product/brakes/evosport/es-e55rotors-front-rear-slotted.jpg)
