Negative camber...
Old Feb 12, 2010 | 09:40 PM
ssonss1's Avatar
Flying Spur
Negative camber...
I wondered why my tires only last 10k km, inner wear
the outside of the tire doesn't even touch the pavement
Old Feb 12, 2010 | 09:52 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Gonna happen....
if you run her that low! Have you installed the crash bolt kit on the rear? may help some, but if she's going to stay that low, might not.
Looks crazy nice though....
Old Feb 13, 2010 | 12:19 AM
beauphus's Avatar
CLS55 & CL CK60
i made the same sacrifice...it looks bad a$$ but costs quite a bit...i get 6k out of my nittos but i turn a lot of heads doing it...dont know if they will ever have a camber kit the fixes a car sitting as low as mine...
Old Feb 13, 2010 | 11:10 AM
amgbg's Avatar
CLS63 AMG
I had an alignment done right after I put new Hankooks. Outside was looking good. Then I looked and the inners was worned down to the belt. Had to get emergency order of tires. Really ticked my off. The guys at the shop checked the alignment and said all were within specs. My brother in law (M5 owner) says german performance cars have a negative camber for better handling. I only got 15K on the inside of the Hankooks. From the looks of the outside, I have 5-7K more to go.
Old Feb 13, 2010 | 08:36 PM
soulsearcher's Avatar
SL600 (1000 hp), Cayenne S, 996TT EVO GT750, F430 Spyder,A real Ford GT, 08 Gallardo Spyder
Mine is lowered and averages 4k miles for rears and 6k for fronts. I added K-macs and it does help however I decided to go back because the car handled much better (obviously) with high neg. camber due to the additional camber thrust (I race). Obviously I can choose to drive at the oem ride height and that would take care of the problem. K-macs will set you back about 1500-1800 per axle (p & L).
Old Feb 14, 2010 | 12:25 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Pure stock with alignments at every 5k mi gave me 27k on the fronts.
Old Feb 16, 2010 | 10:25 AM
thisisvybe's Avatar
CLS55 - SL55 - RRS Supercharged
I have the same exact problem, I just got new tires around 3k miles ago and I wouldnt be surprised if they were already gone. Im willing to pay that cost to have it looking good
