Resonator removed and check engine light came on
If you have a scan tool, see what code(s) you have...
Are you getting any different odor from exhaust like phosphorus smell as that may be an issue with an O2 sensor
The main causes of cat failure (or the reason why you're smelling such a smell) are due to lead, silicone or phosphorous contamination within the exhaust system (or cats to be exact).
Lead... Thankfully has been removed from most of today's consumer based fuels. It is and can still be found in some high-octane race fuels or additives, which you shouldn't use on an emission controlled vehicle.
Silicone... Usually finds its way into the exhaust system through a coolant leak within the combustion chamber or more familiarly a head gasket. Believe it or not, some oil and fuel additives also contain silicone. In small amounts it may not be as harmful, but when used improperly (like pouring in 2 or 3 times the recommended amount) is when it can cause irreversible damage. Silicone can also cause havoc and permanently damage O2 sensors.
Phosphorous... Comes from motor oil (even though newer oils are said to contain little to none of it, they still do), and under normal conditions shouldn't be a problem for a "healthy" cat to keep under control but an engine that is burning oil from lets say bad valve guides, seals, rings, or gaskets will naturally contaminant even a "healthy" cat. This contamination in essence clogs the cat(s) and when the cat & exhaust system warms up, it emits the phosphorous smell you're picking up.
An internally damaged or broken cat can also be a culprit, as it's prevent the gases from properly flowing through. Any pocket or blockage can cause contaminants to be clogged or trapped. Even a small clog, due to the increase in heat, can render a cat or even the whole emission system useless.
A bad O2 can cause irregular smells from the exhaust, but it's usually more a "raw gas" smell than anything phosphorous like.
If by any chance you do get some sort of O2 or emission related code, I would carefully examine the rest of the exhaust system which may help you determine if there's anything else wrong with your car.
Just some more food for thought...
