MOTIVE Brake power bleeders now in stock
Former Vendor of MBWorld
We just got our order of power bleeders in stock from Motive. If you do your own brake bleeding in your CLS than this will make the job easy for you. I was amazed how filthy the brake fluid get's on these cars. Whether you are adding our stainless steel brakes lines or you just want to renew your fluid, this brake bleeder will make the job easy for you.
Motive Power Bleeder- $50.00
Fluid- $15/liter
Stainless Steel brake lines- $150.00/set of four
Project Mu brake pads (coming soon)-
-Front- $375.00
-Rear- $200.00
We have the fluid, stainless steel lines and Motive Bleeders in stock and ready to ship.
Fluid- $15/liter
-Front- $375.00
-Rear- $200.00
06 CLS55 AMG
Just a FYI, I've personally used the Motive power bleeder on multiple occasions and it's by far the easiest and quickest way to bleed your brakes - period!
It really takes the guess work out of bleeding brakes, and makes other bleeding aids like a mighty-vac seem archaic.
Just to give you an idea on how fast and efficient this unit is, granted you have easy access to the bleeder valve on your brake caliper (in other words you don't have to remove your wheels), you can comfortably bleed all four corners in under 15-20 minutes!
If you're an avid DIY'er, this is one tool you should definitely have in your garage or tool box! Best $50 you'll ever spend!
