esp malfuntion?
Old Oct 15, 2010 | 10:37 AM
paulfromtulsa's Avatar
esp malfuntion?
i keep getting a esp malfuntion. it stays there for a while and then goes away then comes back every once in a while. do you guys know what is going on?
Old Oct 15, 2010 | 06:11 PM
val69's Avatar
Chevy Cavalier(206,000 miles)
Directv
ESPN is on channel 206
ESPN 2 is on channel 209
I hope that helps!
Old Oct 15, 2010 | 09:18 PM
j21importer's Avatar
07 E63, 04 discovery
We probably wont be able to diagnosis for you without some kind of code. However i have seen steering angle sensors go bad.
Old Oct 15, 2010 | 10:37 PM
Esleeper's Avatar
CLS
If it's under warranty take it to the dealer. There is an easy fix but requires taking apart the steering colum a bit to replace the sensor. Don't know what the sensor runs. It's common in the 06 cars and can be an intermittent problem also. Some people can make it go away if you cycle the steering wheel all the way to the right and then all the way yo the left. Turn the car off and then back on. When mine failed it was intermittient but after a week or so it would fail after every start up. Mine also caused an airmatic failure and the ride got stiff as well. Took the dealer only 2 hours to replace. It's an actual sensor in the colum/steering wheel area. Hope that helps.
