Bent Wheels!?!?!
Old Oct 22, 2010 | 02:37 PM
TraumaDude's Avatar
2019 S63, 2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
Bent Wheels!?!?!
I replaced my OEM 19 inch wheels this summer with 20 inch wheels. When I had the OEM wheels taken off three of the four were bent. I just noticed this morning that both driver's side 20 inch wheels are bent.
What is going on!?!? Does anyone else have this much trouble. I assure you I am not driving through any war zones. All my driving takes place in the Greater Cincinnati area. Granted there are some bumps here and there, but I don't make a habit of hitting potholes. Any thoughts?
Old Oct 22, 2010 | 04:13 PM
nJuDunno's Avatar
Its the price you pay for going with 20's. There's not alot of rubber to work with with to give way on bumps. Maybe you are keeping the tire pressure too low?
Old Oct 22, 2010 | 07:06 PM
ssonss1's Avatar
Flying Spur
+1 on the tire pressure, I usually keep my 20s at around 42-45psi
Old Oct 23, 2010 | 01:28 PM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
40 is the best for low profile......the TPMS will light up under 31 psi..
Old Oct 23, 2010 | 02:54 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The problem that you have is that your going with larger wheel and tires. The bigger you go the smaller the tire sidewall is. The sidewall is what absorbs impact from bump in the road, and since your sidewall is so small, the tires can't absorb bumps, transmitting that energy into the wheel. because it to bend. I understand that everyone like 20", but honestly 20" wheels aren't good for a heavy car like a CLS. If you must run a 20" wheel and tire combination, get tires with a taller side wall like 40 series.
Old Oct 24, 2010 | 10:47 PM
nJuDunno's Avatar
If you got a taller profile, you will definately throw off the speedo and probably have rubbing issues
