CLS500 with a AMG 55 motor installed
Old Oct 27, 2010 | 12:32 AM
  #51
bigbodybeeenz's Avatar
bike
What about the transmission? Can it handle the extra power no problem?
Old Oct 27, 2010 | 08:40 PM
  #52
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
7 speed works, but it won't last if I drive the car hard. 7 speed is also having trouble pairing up with the ECU. 5 speed should be installed soon though. This motor is very strong, and feels amazing .
Old Oct 28, 2010 | 03:41 AM
  #53
apdesign's Avatar
Amazing work bro. You are very talent. You can pretty much do anything.
Old Oct 29, 2010 | 09:05 PM
  #54
khelawanb's Avatar
Thank you for the kind words apdesign.
I took a steel brush that I bought from Auto Zone and went to work on my Supercharger. It's much cleaner. It seems like the dirt and grime would never come off, but the brush did the trick.
Old Oct 30, 2010 | 09:17 AM
  #55
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
Originally Posted by khelawanb
My alternator is performing well, and keeping my audio very happy:
http://www.youtube.com/watch?v=PZ0tZImESqU
No more dimming of lights etc.
if engine's off, as it seems in the video, you are not mentioning your new big battery ..
Old Oct 30, 2010 | 10:29 AM
  #56
khelawanb's Avatar
Yes, you are correct dyno
I have two XS batteries, D3100 & D6500. My last alternator was going bad, and was never able to keep them fully charged. Dyno, I recommend getting this done to an alternator. I drove the car all day yesterday and abused my stereo for a while. I noticed that my amps stayed cool, and did not clip or cut off at all due to over heating like they did before. I didn't get any codes from the juiced up alternator. Plug and play.
Old Oct 30, 2010 | 11:05 AM
  #57
khelawanb's Avatar
I also changed the design on my speaker box. This one functions better. The subs fire toward the rear then bounces back into the car through the armrest port.
Old Oct 31, 2010 | 10:48 AM
  #58
dyno's Avatar
true, a proper charging system and proper battery pack will preserve your gear, too (just because as voltage lowers while you keep demanding the same output wattage level, the consequence for balancing that is an higher drain and flow of the residual current, or amperage, which makes your amps hotter ... W = V*A )
now you have best of both worlds: the upgraded Alt provides what is demanded when the engine is running while the upgraded Batt keeps up when it is not running.
btw, I had a look at XS specs and I suppose that you could locate the big 3100 batt in place of the stock one.. but where did you put the other one ?
now I see why you were after the torque of our 55K engine ... you probably have around 200lbs more weight because of that audio system
but, these are just details ...
back to your really serious Engine swap mod: if I understand correctly the stock 55K ECU supports the traction control electronics embedded in the 7-speed tranny (even if dyno mode only) .. and this is really astonishing to me
.. really you are able to change gears from first to seventh ??
Old Oct 31, 2010 | 09:41 PM
  #59
khelawanb's Avatar
Yep! To my surprise, it changes the gears just fine. Car also feels like it's adapting well, and it felt even faster today.
I had a great day today. I was invited out to a local AMG meet. Here are some pics from the event:
The event was held at Euro Motors in Bethesda MD. They really took care of us, and sponsored catering for the event. People there were shocked to see the swap and had lots of questions. I had fun chatting about the build.
Old Nov 1, 2010 | 06:57 AM
  #60
dyno's Avatar
and for the occasion you didn't miss replacing something else .. I see down there in the bumper ...
was watching again your video hoping to see how crazy short must be its first gear but unfortunately you should have 2nd in ..
Old Nov 1, 2010 | 01:04 PM
  #61
khelawanb's Avatar
Took a few test runs yesterday. Nothing big, just showing a friend the new birth of power
http://www.youtube.com/watch?v=572c4tx0B4A
Plan on taking it to a place with less traffic and really open her up on video
Old Nov 1, 2010 | 01:15 PM
  #62
khelawanb's Avatar
LOL! You mean the daytime running LED fogs?
You might be right with the gears, hard to tell at times
Old Nov 1, 2010 | 03:25 PM
  #63
ShangoAshe's Avatar
2020 AMG GT-R PRO
do you think you'll ever run your car on the track?!
Old Nov 1, 2010 | 03:51 PM
  #64
bigben320e's Avatar
CLS63 Designo Edition, Hyundai Genesis 3.8 , Veloster Turbo, CLS500(Sold), E320 (SMOKED) R500 (Sold)
Brent, so are you still replacing the tranny or sticking with the 7 speed?
Old Nov 1, 2010 | 04:22 PM
  #65
bigben320e's Avatar
Great vids, looking forward to more. BTW, when you do change the tranny out (I missed one of your posts above), will you be posting pics of that change out?
Old Nov 1, 2010 | 04:44 PM
  #66
khelawanb's Avatar
Yes! The car will always be a dedicated show vehicle, but it will be on the track when its finished
Old Nov 1, 2010 | 04:45 PM
  #67
khelawanb's Avatar
I will post pics of that for sure bigben
Should have the tranny soon.
Old Nov 1, 2010 | 06:16 PM
  #68
ShangoAshe's Avatar
2020 AMG GT-R PRO
Alright i'll take your word for it, I certainly can not wait to see that beast on the track!
You better make sure you keep all of us updated WHEN you actually go and race!
Old Nov 6, 2010 | 02:32 AM
  #69
khelawanb's Avatar
I upgraded my water pump to the CM30 Johnson Pump. Huge difference!!!! It looks smaller than the oem pump, but pumps 3 times the fluid. Wow! System seems to be operating much better, but I won't stop until I have a Monster Heat Exchanger.
Originally Posted by Sonny@Marranos
That is a grewsome task you took on there,well done !!!! Get a good size heat exchanger and a really good intercooler pump to pump the fluid & put it in a location where theres plenty of air flow,as long as the temps stay down,performance will be consistent.
regards sonny
Old Nov 6, 2010 | 11:12 AM
  #70
LantanaML320's Avatar
2004 Chrysler Crossfire
Great job on the conversion! You may want to consider the SL55 heat exchanger. It should fit in front of the condensor but you may have to make a braket. Glad Rudy at Accelerated was able to get it running!
Old Nov 6, 2010 | 12:09 PM
  #71
khelawanb's Avatar
Thank you Lantana, and thanks for all of the info and phone calls that brought me to this point.
Watching Rudy work was magical . It's hart to describe, but watching a motor return from the dead is amazing.
I am doing aftermarket heat exchanger for sure. All AMG heat exchangers are very similar in size and very small.
Old Nov 7, 2010 | 10:07 PM
  #72
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
The wire brush did great, the K.unit looks brand new! Very Nice!!!
Old Nov 8, 2010 | 11:47 AM
  #73
phat209's Avatar
W209, W219, 2001 FD3S
Khelanwab- the car looks awesome!! Hints on where i can get those LED daylights? Cheers
Old Nov 8, 2010 | 12:47 PM
  #74
bogota's Avatar
CLS55AMG
Thumbs up WOW....
I admire your dedication to the project and the determination to get it done. Hats off!!! Very clean..
Old Nov 9, 2010 | 06:17 PM
  #75
BenzoBoi's Avatar
Super Moderator
W221
Awesome job!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
