Fog Light Got Busted, Where To Get Replacement?
Old Jul 16, 2011 | 03:49 PM
CLS550's Avatar
Subway
My left foglight is not working on my CLS500 with sprt pkg (Same as CLS55).
It seems like some road debree hit it cause its a bit chipped and seems like that caused it not to work. Where can I find a replacement for this?
Old Jul 16, 2011 | 05:53 PM
DucatiGuy's Avatar
06 CLS55 AMG
Most likely the problem is just the bulb, which by any means is a relatively inexpensive component, but if you wanted to replace the entire fog light assembly (housing and glass), it'll set you back around $224ea from the dealer.
Another alternative to the dealer (for genuine parts) is parts.com, which carries the OEM genuine MB fog light at a 40% discount. Cost to you will be $134 + shipping.
Last but not least, you can also find aftermarket fog lights online on such sites as eBay for as little as $25-$40 each, but beware most of these have front lenses that are made from plastic not glass, and are built to much lesser standards of quality. These are often the units you see that "fog up" or haze after a few weeks of use.
Old Jul 16, 2011 | 05:55 PM
tbal's Avatar
Haters crazy
pelican parts had them for 75$, seen some oem style (not oem, but look identical) made by DEPO for $140 pair.
Old Jul 16, 2011 | 08:15 PM
CLS550's Avatar
Subway
Ok, so what I really need is just the bulb then? Where can I get that?
Old Jul 16, 2011 | 10:24 PM
keith954's Avatar
cls55
The bulb is a H7 bulb, any auto parts store should have one.
Old Jul 16, 2011 | 10:52 PM
apdesign's Avatar
Does anybody actually knows the part number for the whole fog light unit. My right fog light glass lense broke off...a size of a quarter. CAn just just replace the lense oppose to the whole unit? Thx in advance.
Old Jul 27, 2011 | 11:21 AM
TraumaDude's Avatar
2019 S63, 2006 CLS 55, 2005 Infiniti QX56, 1994 Softail Springer
Grille, Fog Lamp CLS550
w/AMG Styling Pkg R #.3 219 885 06 53 $174.00
L #.3 219 885 05 53 $174.00
I replaced mine myself. For a VERY novice mechanic it wasn't too difficult.
Old Jul 29, 2011 | 02:16 AM
apdesign's Avatar
Thank you very much TraumaDude.
