Front suspension
Old Aug 19, 2011 | 02:24 AM
Norman yafai's Avatar
CLS55AMG
Smile Front suspension
Could anyone tell me what to buy ? I have a message coming up in the dash board saying "stop car too low" and I noticed front right side is way down to the ground , what is it I need to replace , and which brand is the best ? My car is CLS 55 2006 .
Old Aug 21, 2011 | 02:04 PM
DucatiGuy's Avatar
06 CLS55 AMG
If it's just one corner, chances are you have a bad strut or air line (broken, kinked, etc). The problem can also stem down to the suspension pump, but that usually involves either the entire front end or rear, or the the entire car being too low....
You'll need to check out everything, pump, controller, lines, fittings and struts to find the problem...
And as for what or where to buy, your best bet is the dealer for these items...
Old Aug 21, 2011 | 02:34 PM
CLS55AMG
Thank you for your reply , I have decided to take it to the dealer .... Thanks
Old Aug 21, 2011 | 06:24 PM
juicee63's Avatar
2011 twin turboed prius
You can hear if the pump and or airline is bad. More than likely it is a failed strut.
You can buy them after market for about 1/4 the cost. The dealer will charge 1000-1500 to replace.
when you go to raise the car get next to the wheel and see if you hear the air leaking out and or do not hear the pump that pumps the air.
Good luck, this is a common prob for cars with airmatic
Old Oct 9, 2011 | 10:51 AM
bjjfan's Avatar
clk320
Hello Norman,
I am having the same problem with my CLS55 w 38k miles. Do you mind sharing what the repair was and cost.
thnx
Old Oct 9, 2011 | 03:23 PM
CLS55AMG
Hi , bjjfan .,
I took it to local Mercedes dealer I was charged 1600 USD for new front right suspension including labour , they give you a two year warranty , which makes it a little less painful !!! , I could not get the same suspension from any other OEM , ....
