Need an engine 2006 CLS 55 amg
Old Feb 9, 2012 | 04:42 PM
ssalib428's Avatar
Had a problem an engine problem when driving a 2006 CLS 55. Did a couple runs over 130 mph last week and during last run at close to 140 mph felt gas pedal shut down lost power and immediately the check engine light came on, also started smoking immediately. Pulled over right away and turned the car off and started it again to try and clear codes. Car was shaking very bad during idle. When right home opened the hood and found oil cap seal blew and oil was all over the engine. Took the car to the mechanic over the weekend. They did a compression test yesterday and said the problem is a blown piston. Mechanic said that rebuilding the motor is not and good idea since they are hand crafted by amg and didn't want to take a chance. Also after talking to several other mechanic's and reading other posts online, it sounds like replacing the engine is the best solution. I would appreciate any imput from other members to help me in finding a good engine at a responsible price. I already checked ebay but only saw 1 amg 55 engine with 94k on it. Any additional imput would be helpful.
Old Feb 9, 2012 | 05:03 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Contact a member named Shardul.. Or Exotic- Metal, either one of them should be able to help you out..They are usually found in the w211 section..
Good luck
ssonss1's Avatar
Flying Spur
What kind of mods were done to the car? Post in the w211 55k section i'm sure someone can help, good luck
Old Feb 9, 2012 | 05:11 PM
vipermike's Avatar
Viper SRT-10, CLS 55 AMG, 2012 Tacoma Off Road 4x4
+1 on any mods done to the car or bone stock??
Old Feb 9, 2012 | 05:26 PM
ssalib428's Avatar
Good luck
Thanks I will check with them and the w211 section.
Old Feb 9, 2012 | 05:30 PM
ssalib428's Avatar
The car was just purchased about 6-7 weeks and I think it had a stage 2 kit for the supercharger, which changes the pulley and reprograms ecu.
I was thinking this may have caused the problem. What do you think?
Old Feb 9, 2012 | 05:59 PM
ssonss1's Avatar
Flying Spur
Def a contributing factor. Any idea on which tuner was used?
Old Feb 9, 2012 | 06:06 PM
ssalib428's Avatar
Not sure what kind of tuner it had. Trying to do some more research to find out more info.
