High pitched noise coming from engine
Old Jun 16, 2012 | 09:44 PM
mannionr's Avatar
2008 CLS63
I bought a 2008 CLS63 a few months ago, and just noticed a high pitched noise coming out of the passenger side of the engine. I hear it mostly in park, or when I come to a light.
It's a very high pitched noise which seems to go away when I rev the engine, or while I'm driving. It may just be because the engine noise drowns it out, not sure.
I've not noticed any idle problems, problems in acceleration or shifting issues, so I'm not sure what this might be. Somewhat afraid of what the dealer might say, as the warranty is up.
I've searched the forums and only found one that is similar to mine, that talks about the same noise being a torque box converter.
Any insight?
Old Jun 18, 2012 | 10:55 AM
mannionr's Avatar
2008 CLS63
Update, couple of edits, still looking for a response.
Noise is not from one side of the engine, sounds like it's from the middle now. High pitched constant noise at low rpm, or idle. When I turn the car off, it makes a louder high pitched noise for about 2 seconds, and then fades out. It also sounds like it's decompressing while it's making that noise, as it sounds like air is coming out.
No drivability problems at all. Any ideas?
Old Jun 18, 2012 | 11:48 AM
CLSFiftyFive's Avatar
09 s550 4matic
Supercharger?
Old Jun 18, 2012 | 11:52 AM
mannionr's Avatar
2008 CLS63
Haha, I wish! The 63's don't have superchargers on them.
I just found something on this forum that might be the answer. I'm going to try the dipstick thing to see if the sound goes away, and then just take it to the dealer and hope for the best.
DTB S-B-01.20/24 FEB09 ML63, C63, CLK63, E63, CL63, CLS63, S63, SL63, and R63 up to engine # 156698x 60 022000 - whistling sound from the engine compartment (in the area of the firewall) the cause may be a malfunctioning diaphragm in the pressure-regulating valve. The sound can also be heard for up to several seconds after the engine is switched off. The sound goes away when the engine dipstick is removed. To resolve, the valve is replaced.
Link: https://mbworld.org/forums/c63-amg-w...mpartment.html
Old Jun 18, 2012 | 12:08 PM
09 s550 4matic
Good luck!
Old Jun 19, 2012 | 10:40 AM
AmmarYasirA's Avatar
W219 CLS63
I wish I could help, but it wouldnt hurt to ask the dealership if they would just "check it" for you for free.. Some dealerships dont mind...
Old Jun 19, 2012 | 11:30 AM
mannionr's Avatar
2008 CLS63
Ok, so yesterday when I got home I tried the "dipstick" suggestion mentioned in the DTB. Upon taking out the dipstick, I could hear air release (not sure if this is normal or not). The noise completely went away. So I was pretty certain that this was the issue.
I took it into the dealership today, had a tech look at it. The service writer said that he talked to his lead tech and they have not had one person come in to that dealership with that DTB and that it was very obscure.
They called me back, and indeed said that it was the pressure valve that needed to be replaced, and that it sits behind the intake, etc, etc.
$675.00 Total Cost. Going to pick it up at the end of the day or tomorrow.
Do you think that there are any dealers that would pick up this cost for a car out of warranty, with a known DTB?
Old Jun 19, 2012 | 11:52 AM
W219 CLS63
Im a newb, help me out, is a DTB a recall?
the only way to check if dealers will pick up the cost without warranty is to call around..
some dealers are a pain in the a** and others will do anything for you..
