CLS55 wheel offset?
Old Aug 1, 2012 | 07:17 PM
TZL's Avatar
TZL
SL55 AMG, CLS55 AMG, Nissan GT-R, BMW X5 35D, Ferrari 458 Italia
CLS55 wheel offset?
So the stock CLS55 wheels are 25/28 offset, 8.5" front, 9.5" rear
However I want to buy some replica OEM wheels, same width and the seller claims that the 35 offset won't be a problem all around, can anyone confirm?
Old Aug 1, 2012 | 07:23 PM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
Pretty sure 25 front and 28 rear.
Old Aug 1, 2012 | 07:59 PM
frontin55's Avatar
n/a
Stock CLS55 offset is 25 in the front and 28 in the rear. The 35 offset will fit, however if you want the "flush" look then you will need a 10 mm spacer in the front and 5 mm spacer in the rear.
I wouldn't recommend putting replica wheels on a CLS55 though.
Old Aug 2, 2012 | 01:14 AM
TZL's Avatar
TZL
Where can I find a good deal on one factory rear wheel?
Old Aug 7, 2012 | 01:43 AM
AmmarYasirA's Avatar
W219 CLS63
Lol, if I get around buying aftermarket wheels I might sell em to you, when do you need em'?
Old Aug 7, 2012 | 09:17 PM
topshootar's Avatar
CLS55, Town Car
will 20mm spacers destroy a cls55 in the front and back?
Old Oct 17, 2012 | 11:47 PM
adrenaline12055's Avatar
W220
If your still interested. I have a set of authentic CLS AMG wheels for sale. All 19x9.5 rears. I'm have pics on my car in the w220 show off thread. Pm if interested.
Old Oct 18, 2012 | 02:09 AM
Kelvin07's Avatar
CLS55 AMG, ML63 AMG, Cayenne S
Do this, go oem, your car will make you regret you got it cheap replicas, they all pretty much suck
Old Mar 6, 2014 | 12:53 AM
sincerek44's Avatar
2006 CLS55 AMG
OK! MB Family. Just bought 2006 CLS55 want to add 24 for stylish look the set I like are:
Item specifics
Condition: New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is applicable). Packaging should be the same as what is found in a retail store, unless the item was packaged by the manufacturer in non-retail packaging, such as an unprinted box or plastic bag. See the seller's listing for full details. See all condition definitions- opens in a new window or tab ... Read moreabout the condition
Rim Brand: 2 Crave Alloys
Number of Bolts: 5
Rim Material: Alloy
Bolt Pattern: 5x114.3, 5x115
Rim Width: 9
Hub Bore: 78.3
Rim Diameter: 24
Rim Structure: One Piece
Offset: +15
Old Mar 6, 2014 | 03:01 AM
TheVazha's Avatar
W213 E63
Bro do you have any crazy wheels to sell me or trade me for the 547's in 20? PM me nao!
Old Mar 6, 2014 | 04:32 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Sincerek44 Welcome to the board! Look under your front fender. Tire diameter can't grow much due to the upper ball joint, and I thought the bolt pattern was 112??? Maybe not.
Old Apr 15, 2017 | 11:03 AM
mercedeslady@oc's Avatar
2006 mercedes CLS55 AMG, 2003 mercedes ML500
so I have 2006 CLS55 AMG and we bought after market chrome rims made by Mandrus-Mannheim chrome. the front is +32 offset and the rear is +53 offset and we have tried spacers on it and the car still has a shake to it, but not with the factory rims. we used 25mm spacer on the rear and a 5mm on the front as well as tried a 10mm on the frontand a 15mm on the rear. Any suggestions will be greatly appreciated.
Old Apr 15, 2017 | 04:06 PM
TheVazha's Avatar
W213 E63
Your spacers are not the problem, assuming you have the correct hub bore spacer.
I will bet anything that your wheels weren't properly balanced. A lot of wheel tire package combos just slap the tires on with out a proper balance. Also people who don't know what they're doing are dangerous. Make sure they have quality equipment and do high performance autos.
Take your car to a reputable performance shop that sells expensive wheels. Ask them to balance your wheels. It should cost no more than $80-$100 for the whole car. It will be the best money spent and your car should ride like stock wheels do!
Old Apr 15, 2017 | 04:08 PM
TheVazha's Avatar
W213 E63
Also don't say anything about vibrations, you'll most likely get turned away as high caliber shops don't want to inherit someone else's sloppy work. It ain't worth it for $100. Just go in and say you'd like a tire balance. That's it.
Old Apr 17, 2017 | 08:57 AM
Going to send them back to wheel company. We had them balanced and still the same thing. Not going to deal with it anymore, just going to buy OEM. thanks.'
Old Apr 18, 2017 | 03:47 PM
FunkTron's Avatar
2006 CLS55
smart man. If they can't be properly balanced, there is something major going on. Not worth the headache.
