vellano offset help
Old Aug 30, 2012 | 02:08 PM
CLSFiftyFive's Avatar
09 s550 4matic
vellano offset help
Hey mbworld i just got a set of vellanos that are 20x11 with an offset of +33 woth a 295 tire. I would like to put a spacer in the rear as its just not as aggresive as i would like it to be. Can i go with a 12mm spacer putting the offset at +21 or is that too aggresive? Lile i said im running a 295 so hopefully i can fit it, i know most run 305s on a 20x11..
thanks
Old Aug 30, 2012 | 02:10 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Spacer would be fine....My wheel was 20x11 with 23 offset.
Old Aug 30, 2012 | 02:17 PM
09 s550 4matic
So 295 tire at +21 offset with lowering module i should b ok? Forget to mention lowering module
