Drivers touch outside lock problem
Old Jan 18, 2013 | 05:18 PM
Boosted1's Avatar
Cls55
When I go to unlock my car using the handle it never seems to unlock. When I get out and lock it it always works. I've searched and found a few people change the handles. I can't find a list of all part #'s that will be needed. Will I need to get it programmed to my key?
Old Jan 19, 2013 | 02:28 PM
M1RAG3's Avatar
CLS550 AMG Pkg.
those keyless go handles are notorious for failing as water gets inside of the assembly as your car gets older. You will not have to program a new handle to your key as the handle is hardwired to the car (i.e. plug in a new handle and it will work). I would not recommend trying to do this yourself on the CLS, it is not as easy as the E class, for which there is already a DIY on these boards. I had my driver's side handle replaced by the dealer for exactly the same reason, cost a lot though
Old Jan 20, 2013 | 09:54 PM
Boosted1's Avatar
Cls55
Thanks for the info. So I should just deal with it huh? It's not that big of a problem yet, just kinda bothers Me because i know it doesn't work
