Are E55 and CLS55 brake rotors interchangeable?
Old Aug 19, 2013 | 08:09 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I have a 2006 E55 that I put Evosport 2 piece rotors on less than a thousand miles ago . I just picked up a CLS55 that I'm going to build instead of the E, and I was hoping to swap the brake rotors onto the new car.
The E has EvoSport's 390mm upgrade, and the CLS has the 030 package with OEM 380mm. Anybody know for sure before I start taking things apart ?
Old Aug 20, 2013 | 12:22 AM
cm60k's Avatar
When you upgrade the E brakes from Evosport, did you change the Calipers...??,
cause the OEM only handle 360mm...!!
ZAYED,,
Old Aug 20, 2013 | 06:17 AM
The calipers stayed the same on my E, the rotors came with spacers to move the caliper away from the center of the spindle about 10-13mm
Old Aug 20, 2013 | 07:36 AM
cm60k's Avatar
In generally; E55 & CLS55 uses the same brakes, but since you have 390mm, that means you have the S65/SL65 calipers,,
most tuning companies upgrade all 55s brakes from the 65s set-up, with different Rotors shape....
ZAYED,,
