airmatic sensor height adjustment
Old Jan 19, 2014 | 01:06 AM
tommy350's Avatar
06' Lexus IS350
I was washing my car today and i noticed that my car is sitting a little uneven. i'm lowered on a lowering module. I know that our cls have 3 sensors? from what i know, you can adjust the sensor or something to even it out better? i'd take it to the car shop i got the module from and have them adjust it, but if its a quick or easy diy, i'd save myself some gas and time and do it myself.
any one else using a module? anyone else having a little unevenness? the unevenness isn't actually all that much, but since i own the car i'd know it haha
Thanks for the help guys
Old Apr 27, 2014 | 01:49 AM
Pedro terrassa's Avatar
mercedes cls 55 amg
I also have unevenness in the airmatic.
How can be left as perfect?
Old Aug 27, 2014 | 01:24 PM
*AMG123's Avatar
E55AMG
Hi guys, I am owner of an E55AMG'05. My car has an airmatic problem. The diagnosis gives these fault codes (5132-left side airmatic sensor/5142-right side airmatic sensor/5152-rear airmatic sensor)
Airmatic kompressor works fine up and down.
The problem is that car's left side is 12mm down then right side or opposite! (right side is 12mm upper then left side)
While we connect the car to diagnosis,we made felt and right at same balance but whenever disconnect from diagnosis and try to up or down the airmatic, the problem occurs again.
I think a wire contact to chasis,also deaits of the fault code says the same.
If somebody had the same problem,then help me where to start?
Thanks. I am sorry about my english,hope you understand well.
Note: sensors are fine,sockets are fine.
