Supsension Rising Mulfunction
Hello everyone,
So I left my car in the garage for couple weeks without using it and would start it once in a while to make sure the car was starting good. After I started driving it daily again the suspension rising malfunction indicator would show up on my dash. At first it would pop up after I drove for a mile or two, now it pops up right after I start the car. The car does NOT sink, but it also won't rise when i hit the rise button. It works fine when I switch between 'comfort' and 'sport' mode, I notice the difference right away on stiffness. The height on front seems normal and on rear a bit high from where it should be. And I don't hear the suspension letting out air after I have locked the car like I usually used to.
I tried doing some research on this but the case with most people is that the vehicle will sink, which is not the case with my car. I read something about a sticky relay, which may be the case.
Any thoughts or input would be greatly appreciated.
