Weird Driver's window behavior?
Old Jul 22, 2015 | 07:27 PM
useras224's Avatar
All 4 windows roll down a little automatically, when I open the doors. That's normal.
The driver's window rolls down upon opening, but doesn't roll back up when I close the door automatically. It's only on the driver's door that this happens. It did this months ago and went away but it seems to be back. Is this a warm weather related issue maybe?
Old Jul 22, 2015 | 11:24 PM
Flo1989's Avatar
CLS 55, Audi A7, Range Rover Sport
Happened to me about a month ago...Had a lowering module installed and when I got home I realized the same thing was going on with my driver window. Figured it just needed to be reset...Not sure on the proper way to do this but what I did was (with all doors closed & windows up) was point my key at the driver door handle and held the 'unlock' button. All windows should roll down & sun roof should roll back. I then held the 'lock' button to make everything close. My problem was solved. Hopefully this works..
Old Jul 23, 2015 | 12:50 PM
Manofsteelpt's Avatar
Veteran: Army
S63
Just reset it... With car on and door closed, push and hold window button down till it's down all the way, and then up. Should be GTG after that.
