Intercooler pump -- How do I know if it's working?
Old Jul 29, 2015 | 11:32 PM
useras224's Avatar
I'm reading people's responses to maintenance and this item seems to come up quite a bit. Would I get a CE light if it failed?
Old Jul 30, 2015 | 09:05 AM
AndreNY's Avatar
couple of Benzos
I bought my car less then 2 months ago and from the first day I drove it, it felt sluggish and not what it should feel like (even stock these cars are quick) so driving it like that for 3 weeks I really wanted to find out what the issue was no CEL no shaking but I did notice when I was on the highway once I stepped on it (50-120) and I let go of the gas I tried to punch it again the car didn't go anywhere, I knew right there I had a "weak" pump so decided to change it with the "BOSCH 010" and little did you know that solved all my problems the car not feeling like it should since I bought it was resolved and it now moves. Wether you need it or not I would change it regardless the pump is cheap and to change it takes less then an hour, being that our engines run very very hot and have a poor cooling system this should be the first "mod" to do on any 55 car
Old Jul 30, 2015 | 10:29 AM
useras224's Avatar
I apreciate your response. My CLS55 is the only one I've ever driven and I don't know another person that has one to to compare so I don't have a "fast" point of referrence. I've driven a lot of fast cars but since I don't have that reduced power lag you describe, I guess mine's within factory working order.
Say, did you do the separation bypass mod at the same time? I was thinking of doing that. It separates the hot coolant circulating the engine and makes the intercooler a whole separate circuit. I think that requires two pumps if I'm not mistaken.
Any bendors listening? I'm interested.
Old Jul 30, 2015 | 10:34 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
for the split cooling kit all you need is a BMW power steering reservoir, 3/4 hose, 3/4 inch T fitting, 3/4 inch block off cap and some clamps. I would just get a pump and heat exchanger and you will be fine.
I can supply you with a heat exchanger
Old Aug 1, 2015 | 12:24 AM
Wasabiz55's Avatar
CLS55
I found my pump was shot when we hooked up an obd2 reader and connected to torque app. My intake temps spiked to 140-150 degrees and stayed there for a long time after a hard pull on half of 2nd gear.
It's pretty easy to change if that's all you're changing out.
Intake temps should be below 115-120 on a hot day (~90degrees). The ME control unit starts pulling timing at 125.
Bottom/left shows the heat criteria in how much timing is pulled at certain heat ranges
Old Sep 1, 2015 | 06:00 AM
equitiesguy's Avatar
Mercedes CLS 55 AMG
CLS55's don't run hot unless they aren't running properly. In 90 degree weather in Florida, my car doesn't run above 190-195f, even in rush hour traffic.
To answer OP's question, you will not see a CEL light on a completely failed intercooler pump. Best to replace it if your IAT is above 120f.
Normal operating temperatures on IAT is +10 to 15 degrees above ambient. Again, in Florida high humidity, at 90f, my intercooler temperatures are between 95-98f on the stock setup. On a 0-80mph pull it goes up to about 105f, and then right back into the 95f range in 30 seconds.
This is a low temperature circuit. It is independent of the radiator coolant, with a bleedover mix T hose. There's no reason to split the circuit. I seriously question any performance increase by doing it over installing a water sprayer on the intercooler instead.
If you read GF07.61-P-4027AM for the 219, the "retardation of the ignition timing point commences at a coolant temp of approx 90c, and a charge air temp of 20c."
So, on a CLS55 the timing is being pulled after 70f on the IAT.
The improved Bosch 0392022010 replacement pump is all you need and your system will run terrific (Mercedes cross ref#: A0005000386).
Old Sep 1, 2015 | 08:40 PM
useras224's Avatar
So what are you using for a scan tool then? I'd like to see if mine runs as cool as yours. Admitedly, your numbers in the hot FL sun seem a bit low.
Thanks.
