CLS63 how many brake pad wear sensors?
Old Sep 16, 2016 | 11:07 AM
Fivehunnit's Avatar
CLK500 (2002)
About to order some brake bits, but can't seem to find a solid answer about how many brake wear sensors the fronts will need? One per calliper or one per pad? I'm seeing two different part numbers and different prices for what are listed as front wear sensor also, why would that be? Is one for the inside pad and one for the outside pad different?
Old Sep 16, 2016 | 02:39 PM
knownworldwide's Avatar
1995 E320 Wagon
If this helps any my cls55 uses only two pad indicators. One for the rear (passenger rear) and one for the front (passenger front)
Old Sep 16, 2016 | 06:23 PM
Fivehunnit's Avatar
CLK500 (2002)
Originally Posted by Plutoe
for correctness post the VIN!!
WDD2193772A123319 1
Old Mar 3, 2020 | 03:31 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
How many sensor on this CLS55?
WDDDJ76X36A066661
I only see 2 front and rear Passenger side.
Old Mar 11, 2020 | 12:15 AM
CDC55AMG's Avatar
CLS55AMG
With your VIN you have a R and L front sensor.
With your VIN you have a R rear sensor!
My CLS55 also has two in front (left and right) and one in the right rear.
