seat cushion replacement??
Old Jul 26, 2018 | 06:22 PM
LGHT's Avatar
08 CLS 550
Is it possible to replace just the bottom or side cushions on a 09 CLS-550? It has the heater / cooling and all the adjustments, but also has a big tear down the middle.. If you can is it easy to do or is that something you take to a shop?
Old Jul 26, 2018 | 11:37 PM
desired_speeds's Avatar
2007 SL55 AMG
Definitely doable yourself. You'll have to source a replacement leather skin. A lot of times if your leather is worn, the foam on the outer butt bolster has deteriorated as well. Replacing both at the same time would be ideal.
Old Jul 27, 2018 | 11:18 AM
LGHT's Avatar
08 CLS 550
When you say skin are you talking about this?
https://www.ebay.com/itm/152-MERCEDE...sid=m570.l1313
