E service is Due please advice.
Old Jun 9, 2019 | 08:03 PM
JCLS55AMG's Avatar
Mercedes Benz CLS55 AMG
My E service is due on my Cls55 AMG with 106, 000 miles. What does this service consist off in doing to the car? Want to do this ASAP. Please share your knowledge. Thank you 🙏
Old Jun 9, 2019 | 10:06 PM
whoover's Avatar
'19 E63S sedan
What year? E just means 5-hour estimate; it doesn't define a list of services. Do you have the maintenance booklet for your car? I assume the 100K service hasn't been done and is due. The major thing above and beyond a normal complete service is new spark plugs. Probably transmission oil change, maybe brake fluid change. All of these things are dependent on the service history.
Old Jun 9, 2019 | 10:10 PM
JCLS55AMG's Avatar
Just came from the Benz mechanic. He said I need engine oil with filters changed. Differential oil changed. And brake fluid changed.
Thats it.
Going to charge me 500$ with parts and fluids included labor cost all together.
Old Jun 10, 2019 | 04:38 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I believe at 100K miles need to change spark plugs ($300) and tranny service.($400)
Old Jun 10, 2019 | 04:48 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Go into the FSS in your instrument cluster and it will tell you what services are required based upon time and mileage. The last four pages of the attachment are the services.
FWIW, the W219 and W211 use the same diagnostics routine in STAR; so effectively the same car with different bodies and interiors. So...this means you can search the W211 section of the forum for answers about your car.
File Type: pdf
