Smoke from trunk area!
I look inside the at the instrument cluster and it had a red message stating visit workshop and the gauge lights are on. I then hear a loud whirring sound almost like the engine is revving up but the tach read zero and no loud rumble from the exhaust.
From what I gather it was the engine cooling fans running like a turbofan! On and off, on and off.
My next move was to disconnect the main battery to get all of this to stop. Somehow the trunk was unlocked and when I open it up I see smoke and the uncanny smell of electrical burning coming from the drivers side trunk filled the area! 😵😱
I disconnect the main battery negative first then positive in case there is a short to ground.
For added measure I disconnected the Aux battery under the hood too. The smoke dissipated and I pulled the cover of the access panel in the driver's trunk area where the navigation unit is and some fuses and all looked ok. Now that it's light now I will investigate further.
Going to have to be towed to the dealer.
Has anyone ever had anything like this happen?
I had not even driven the car since 8:45pm Tuesday.
Is there anyway to get it into Neutral while batteries are disconnected... My guess is no.
Thanks!
I thought this white relay was the problem but it was not melted and just discolored due to heat.
