Headlamp leveling diagnosis
Old Sep 8, 2019 | 04:39 PM
ZeroG3's Avatar
2009 CLS63 AMG w/P30
I figured I'd start my own thread here (W219), after performing the modification mentioned here (C219): https://mbworld.org/forums/cls-coupe...motor-fix.html
  • Issue: Driver's side Bi-Xenon lowbeams do not perform self leveling, and is too aimed too low.
  • Vehicle and context: '09 CLS63 AMG w/P30, recently acquired, apparently this system was missed in PPI, and I didn't do a test drive at dark so this was overlooked.
  • Information: No dash messages or STAR errors regarding active headlamp system.
    • Passenger's side (autoleveling working) was recently replaced. Assembly and light quality looks good. Driver's side light seems considerably more yellow, and the assembly lens has internal cracking/bubbling.
  • Attempted fix: I've performed the washer shim mod over the leadscrew (found in the thread linked above) without removing the motor from the assembly. This did not solve the issue.
    • Manual height adjustment of Driver's side is possible, and is retained after being set. This is the temporary fix until the proper solution is found.
  • Hypothesis: The motor is not turning. I noticed that the motor lead's wire insulation was very fragile and partially broken, but not shorting.
    • Is there a possibility that there's a heat related issue? Indicated by yellowed light, condition of lens, condition of motor wire insulation.
Question: Is there any way to confirm that the motor is the culprit, and not some other component of the auto leveling system? What could malfunction and not throw an error?
