Hi everyone,
I’ve been reading on this forum for years but never posted before so here we go.
I own a cls 3l diesel 58 plate.
I’ve got 2 problems:
1. When engine is cold I turn on the car shift it to D position, car turns off if I don’t drive straight away. I drive for 2 minutes and then is fine. The car turns off even if i reverse when engine is cold.
2. When I drive on a motorway and I press the gas pedal the car will vibrate for a couple of seconds and then pushes forward as normal. (The vibration is like you start driving a manual car with the second or 3rd gear).
Any help will be really appreciated because I’m driving abroad this Christmas and I’m not sure If I can drive this car.
Launch readings (picture attached)
Note: I’ve changed the transmission oil recently.
The car has 150k miles on the clock.
Best, E
