Lowering module and alignment questions
I have CLS55 and H&R lowering module 29241-2. I haven't done an alignment when I got the car and currently I'm replacing 20" wheels with new 19" ones. I'm thinking to do an alignment for a peace of mind.
Here is what H&R brochure says regarding alignment:
https://www.renntechmercedes.com/ind...owering-module
1) I'm not sure why the alignment is not needed if vehicle is being lowered. You changing angles when you lower your car with lowering module so why alignment is not needed? Please could you give your opinions here.
2) In H&R case it says I need to do an alignment at OE ride height which can't be done wirelessly. I'm going to take my car to Mercedes dealer for alignment. I'm pretty sure Mercedes won't mess with an aftermarket lowering module. I wonder if they can bypass the lowering module and select the needed height with SDS?
3) If you guys have lowering module in your cars how you do an alignment?
Thanks!
