Navigation stuck on same location/intermittent loud beep
Old Jul 8, 2020 | 07:47 PM
MercBenT's Avatar
CLS55 AMG
Hi all,
Recently developed an issue with the navigation in my 2006 CLS55. Navigation is stuck in the same location (i.e., the arrow on the navigation that shows you where you are does not move when I drive around). At the same time, there also developed an intermittent loud, high-pitched beep, that cuts out the sound for about 3 second. When the beep occurs, which is about every 30 seconds, the navigation screen flashes “activating, please wait” for about a second, and then goes back to the map.
The SOS light is not on, and I’ve purchased a separate GPS antenna that I’ve plugged into the back of the nav unit in the trunk, which did not fix my issue.
Any thoughts? I don’t care so much for the navigation since I use my phone for that, I just want to do away with the loud beep as it is really annoying and constantly interrupts whatever I’m listening to.
Thanks!
Old Sep 15, 2020 | 01:01 AM
Radian's Avatar
CLS55 AMG, E320 CDI, E55 AMG
Originally Posted by MercBenT
Hi all,
Thanks!
I have the same problem nav not working anymore and the audio cutting out every few mins for a couple of seconds. If on the serv page of the command when it cuts out and beeps the Bluetooth flashes also and cuts out for a split second
Old Sep 22, 2020 | 10:57 PM
ta72's Avatar
2006 CLS55
Try unhooking the battery for a few mins and re hook. See if it resets.
