Cls 55 no crank no start
Hello
I got a problem with my cls 55 the car is not starting (not even cranking) , i can't hear the pump priming and i am getting abs and esp error , the fan is running at full speed i already checked all fuses and they are in good state, battery is new ,
i checked many thread here in this forum and other some says it is a bad ECU , i took it out for inspection and it look clean nothing burned or damaged (did also quick multimeter check its look ok).
Is there any scheme that can help something like car power sequence so i can check step by step what is wrong with the car ,
i am new to the car world but i am used to soldering and electronic repairs
2006 CLS55 AMG, 2005 SLK 350 AMG
Hello
thanks , i just figured out the issue it is broken pin on the ecu due to water damage , i soldered it and the car started fine ,
if documentation is right it was the pin 16 (sensor ground 2).
strongly enough the car with this broken pin has same behavior as without ECU connected
nd-photo.nl (02-29-2024)
The following 3 users liked this post by machild:
