Cls55 LED tail light upgrade issue
Hey guys,
I installed new LED w219 tail lights, swapped the pins around and installled in line resistors.
followed a members wiring diagram.
driverside tail light -works perfectly
passenger side tail light - dash board shows right turn single error, hyper flash inside vehicle, exterior tail light signals intermittently and very slowly. I’ve got 2x 50w 6ohm resistors on each tail light.
any suggestions ..? I didn’t code out any rear light bulb checks.
Possibly a faulty in line resistor…?
any suggestions would be appreciated.
thanks kindly
thanks kindly
2006 CLS55 AMG, 2005 SLK 350 AMG
This forum does not get a lot of traffic. Since the CLS is based on the W211 E class with primarily only different sheet metal you may get some responses from those forum members. There were a lot more E Class E55 than the CLS55 thus more eyeballs there everyday. Good luck. E55/E63 forum https://mbworld.org/forums/w211-amg-81/
