No ESP ABS Speedtronic after Variant coding
Old Sep 14, 2024 | 03:20 AM
mofa92's Avatar
Cls 55 AMG
Hi guys my name is Mo from Germany.
This is my first post here maybe somebody could give me some guidance.
I raised the speed limit for my cls 55 amg from 230 kmh to 300 kmh and I have no abs, esp, speed tronic, steering wheel is also heavy.
Changing the settings back to original didn't help.
It says: 4A30 ECU no identifed or wrong ECU
5B16: check control unit N47-5
Any help would be gladly appreciated!
Cheers
Old Dec 15, 2024 | 08:42 AM
mofa92's Avatar
Cls 55 AMG
Nobody ??
Old Dec 15, 2024 | 05:19 PM
trigital's Avatar
W213 All-terrain
Can you connect with ESP module?
Did you use Autel/Launch?
Old Jun 29, 2025 | 11:52 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
It is probably the scanner and the need to clear codes. I use Star System and that’s the only way to clear codes in certain subsystems ( like transmission etc.). Changing the limiter should not have changed anything else. Recheck your steps carefully. You may need to find someone with the Star system to correct the issue, or take it to a dealer.
Old Apr 23, 2026 | 04:52 PM
k3no's Avatar
W219 2006 CLS55 AMG
were you ever able find out how to fix this i have the same issue right now?
