Bi-xenon headlight asymmetrical projection image
Old Jun 19, 2025 | 05:18 AM
Mstrszilard's Avatar
2005 C219 CLS 55 AMG / 2008 W204 C 350 4-Matic/ 2011 S212 E 350 CDI 4-Matic / 2013 Smart Fortwo ED3
Hello!
I have a 2005 CLS 55 AMG. The headlights have different beam patterns. The left (driver side) one was also less bright. I was planning on painting the inner silver part of the headlights black. I did this change myself over the weekend. When I took the headlights apart, I also cleaned the lenses. The reflector (inner reflective silver part) on both headlights looked good. After reassembly, the brightness increased, but the beam pattern did not change. Is this the factory beam pattern on the CLS, or are my lights not the same? They looked exactly the same from the outside and inside. The headlights are factory bi-xenon with cornering function. All functions work perfectly. The xenon bulbs is also new.
Old Jun 19, 2025 | 08:30 AM
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
Originally Posted by Mstrszilard
Hello!
You may want to do some search and maybe post your question on the W211 plaform for the sister car E55. Several members there have done extensive work on the head lights so you may find some answers in that section of the forum https://mbworld.org/forums/w211-amg-81/
Old Jun 20, 2025 | 04:32 AM
smgak's Avatar
C230K
Double check the bulb installation. It may not be seated properly.
