Just orderd my camber links...
Cars and boats!
Well, i got through to Jeff and my camber links are ordered... woot woot...
I'll let you all know how they are after i get them!!
265 wide tires + no camber = one hell of a holeshot!!!
BLACK 2005 SLK55 AMG,02 SILVER C32(SOLD),02 ML320 SILVER(Sold),99 S320 BLUE, 03 E500 Sport Pewter
what are the benefits of this besides saving tire life? is handling improved? im getting the kw coilovers on my c32 and was wondering if i really need to order these from jeff. thanks benzoAMGpower
C32
to get the camber kit from my understanding is the ability to adjust your rear camber more. so basically... move flexibility to tune your car to the way you want it to sit.
yeeehaww
turning a AMG W203 into a LS1 camaro drag car!
woo woo
Cars and boats!
"Yea, woot woot, let me take my 3600lb sedan to the road coarse and let loose on all corners..yeaaaaaaaaaaaaaaaaaaa why is that civic passing me on turn 3....... damn, should have bought an M3 damnit!!!"
I dont do much racing at the autoX or road coarse but I do play the role of the weekend dragstrip warrior from time to time... If i wanted a car for the autoX or road coarse I would have bought something lighter and more nimble like an M3.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
The C32 can seat 5, is roomy, has 4 doors, and ultra PIMP factor... performancewise, C32s advantage of having RWD, a drivetrain that hooks and can handle lots of power, and a supercharger so you can modulate throttle to get the car to hook makes it the car of choice for some drag racing. Now how many M3s can cut 1.9 60ft times consistantly on street tires and a slippery track.
Im also real tired of seeing my tires wear unevenly...its about time i did someting about it!!! Im not setting it at positive camber, im just making it so that my tires arent going to wear unevenly.
does not stop the car from crushing just about anything we come across. last time we had the c32 at the streets of willow (in the rain) we had the fastest lap time of the day... not bad for that pig of a sedan. who needs 4wd.. just makes you push like a bus.
Originally Posted by Zeppelin
Don't forget for maximum holeshot to set the camber to 1 to 2 degrees of positive camber. This will compensate for the rear end squatting under load and making the tires more flat on launching. Or you could install a Ford 9" rear end for best drag launches.
Cars and boats!
Originally Posted by CynCarvin32
3650 lb. dry to be exact. wet with a driver its a whole lot porkier... get it right
Cars and boats!
Originally Posted by schwarzwagen
what is ultra pimp about a 4 door benz? it looks like a c230.
how is rwd an advantage drag racing? a moderately tuned s4tt will walk all over you.
stop looking at stock C32s and take a look at a tuned one... ill admit, even a C230 looks good, though looks are subjective, the majority of people here love the way the W203 looks... too bad the C230 lacks a M112K huh.
Also, RWD is an advantage over FWD and AWD at times... want me to post up a video of me holeshotting WRXs and Evos? BTW, my boy has a S4TT, he can definately launch a lot better then the average person...with a set of DRs, I will stick with him on his best launch. I have even stuck with him on my street tires before. BTW, look at the worlds fastest dragsters...they are RWD buddy!!
Also, RWD is an advantage over FWD and AWD at times... want me to post up a video of me holeshotting WRXs and Evos? BTW, my boy has a S4TT, he can definately launch a lot better then the average person...with a set of DRs, I will stick with him on his best launch. I have even stuck with him on my street tires before. BTW, look at the worlds fastest dragsters...they are RWD buddy!! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
i dont think you can do an 11.70 in the 1/4 mile and that's what my friend does with his s4tt.
Also, RWD is an advantage over FWD and AWD at times... want me to post up a video of me holeshotting WRXs and Evos? BTW, my boy has a S4TT, he can definately launch a lot better then the average person...with a set of DRs, I will stick with him on his best launch. I have even stuck with him on my street tires before. BTW, look at the worlds fastest dragsters...they are RWD buddy!!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
S4's can do that .... seen it many times.
and there is no way a C32 can launch as well as that S4. this is crazy! 4 drag radials vs 2 street tires?
are you nuts? lets see an C32 to a 11.70
S4's can do that .... seen in many times.
with regard to the actual topic of this thread, zeppelin is correct. you want to run positive camber not 0 anyway. weight transfer = geometry change.
W203, W211, W219, W212
are we talking about the same thing here ? sorry..
Cars and boats!
schwartz, you obviously havnt seen many tuned 203s.... and no, i dont just have a set of wheels!!! When i said with Drag radials, i meant me with drag radials!! Regarding the 11.7 S4, big whoopie, ever seen a C32 on nitrous pull those times? I have!! Whats the ratio of reliability b/w S4TT and C32 motors and how much does it cost to fix an M112K compared to an S4 motor? Whats the cost to mod an S4, whats the cost to mod a C32, especially for the younger crowd. Most people with C32s dont spend big money it takes to mod it into the 11s, instead if they had the money for so many mods, they'd buy an E55 instead. Some of the younger crowd spends lots of money on C32s but mostly into body/ICE mods, rather then performance. When an S4 is hitting 11s, the reliability goes down as well... if you knew people with Audis then you would know this. BTW, my main reason for the camber kit is to get even tire wear, it just so happens that I will have more tire surface on teh road instead which in turn will give me a better holeshot. Dont got knocking ppl until youve done research kiddos.
C32
How many C32s have you seen with a larger SC, upgraded tranny, upgraded fuel system, better intercooler, etc. You havent, becasue there are no tuners that make kits for them yet. If they did you can be sure that there would be plenty of 11sec C32s.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
find me a KO3 S4 that runs 11.7 and then we will see if its a big deal. K04 cars on the bottle can do it. Not many K03 cars are that fast.
Big whoop you know that the B5 S4's has a habbit of eating up turbo impellers. I wonder why Audi has pulled away from using turbos in their new S4 and RS4... maybe they got sick of warranty work.
All this talk about drag racing has be falling asleep. Back to work....
Watch who you call kidddooo ... kiddoo...
Originally Posted by AaronC
With what mods? Ill bet that he has a engine back exhaust, larger fuel injectors, fuel pump, EM, bigger KKK turbos, stronger clutch, upgraded bypass valves, larger intercoolers, etc.
the car did not make that much power -- more than a C32 but not 500 hp or anything close... not the type of figures you see in these tuner K04 cars
C32
Stock K03 turbos, Stock IC, Stock Tranny, Stock injectors,
2006 SLK 55 AMG
Originally Posted by 360_iti
Along with new 265 tires, my rear cambers were adjusted to -1.54 per MB.
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
JMC
Former Vendor of MBWorld
So whats wrong with the looks of a C230 anyway? is it the price? people think the 300C look "pimp" but if its not over 100k is it not possible?
This kinda BS is funny, lets hear what people wanna call a moderately tuned S4. Because i have seen and knew people with "moderately" tuned S4tts that have not came close to the times Benzo has got with his C32.
Originally Posted by jcanabal
How do you do that? I can barely get -0.58 with OEM camber bolts!!
Is you car lowered? What size wheels do you have to accomodate 265? JMC
i have 265/30/19 rear. see pic.
