C55 Best Tire Air Pressure?
Old Apr 14, 2005 | 06:10 PM
mwiseltier's Avatar
I have Pirelli's on the front and back which indicate a max pressure of 50 psi. What is the best pressure for both front and rear tires. Here in NYC the roads arent the greatest. Don't want to increase chance of blow outs either. Even still, what is the best pressure to keep them at. Thanks.
Old Apr 14, 2005 | 06:30 PM
Marktini's Avatar
2006 SLK55 AMG/// 2006 Porsche CaymanS 2010 135i
I drive in the land of the pothole I usually run about 34 front and 38 rear, for extended highway (high speed) driving I'll add another 4 lbs in each. Some may think this is too high but I'm happy with that pressure.
Old Apr 14, 2005 | 07:42 PM
ajoe's Avatar
I also run 34 and 38 psi which is one pound over the recommend cold tire pressure on the door. Running at the max tire pressure listed on the tire is probably not a good idea.
Old Apr 14, 2005 | 10:38 PM
TEAShea's Avatar
2016 C63
For cold inflation pressure I usually use 3 psi over the manufacture's recommendation for all my cars, including my C55. Remember that pressure will increase about 1 psi for every 10 degrees increase in temperature. Accordingly, when driving on a highway, the pressure increases significantly over cold pressure. When driving on a track, the pressure will sometimes increase 10 psi.
It is interesting to drive a car with tire pressure monitors. I have really learned a lot by this method.
TEAShea
from Nebraska
Old Apr 15, 2005 | 12:53 AM
cntlaw's Avatar
C55AMG W203; 330i E90
If you were often driving in rough bumpy roads city conditions like me; I am using F33 R35 psi that gives comfort as well as good traction and holding. I had two persons on the car and with no sight of performance deficency in doing 200kmh.
