Changed airmass Car is a BEAST!W202 C43/55
George of www.ICSperformance.com felt that the car needed a serious tune up. After a couple of Dyno runs on the Dynojet the car only produced tops 275whp and 286 ftlbs of TQ.I was not happy at all.The E55 motor in my car should be doing at least 284-294whp and 296-301 ft lbs of TQ.So I'm down nearly 20whp and 15 ftlbs of TQ. When I put the 5.5L motor in the car I never chgd the spark plugs.At least not yet.Stupid me. However I never would have suspected a faulty Mass air sensor either.The prior owner of my C43 told me it was new.From reading www.MBworldforums.org There are many posts stating that the airmass has been known to fail even with out setting the CEL.
Well George says lets do everything from plugs to fuel filter to new airmass.I figured the hell with it the car could'nt run any worse.The low whp#'s and several dyno runs was really driving me crazy.The #'s kept getting lower and lower to 250whp.
George ordered 16 new Denso Iridium plugs,new Mass air sensor and fuelfilter and did the install.He also placed an O2 bung in front of the precat for the Wide band O2.Prior A/F #'s went as high as 16.5 and barely into 14.7 in the higher rpm's.LEAN! Like I said this was prior to the tune up.
By the way those plugs by cylinder #'s 3,4,7,and 8 can be a pain in the *** to get to.
So now everything is installed,plugs filter and air mass.We put the the car back on the Dyno and DAMN! The A/F was now down to 14.5-12.2.WHP has now gone up in the range of 290-295whp/TQ 300-311TQ.
We did several runs and the A/F ,whp and TQ stayed in a consistent range. My Gosh! what a difference. I will post my dyno Sat.We did several and I mean several runs.
Took the car on the road,turned off the ESP and the car did a 96ft burn out with both rear wheels locked to my surprise.The topend is scary and the car just pulls like a jet on takeoff.
We gained 20whp and 15 ftlbs of TQ.What a diffference just from changing the mass the car is getting plenty of fuel now.Not only that but the car was getting 300ftlbs of TQ as low as about 3k-3500 rpm's to the best of my memory.
Later on George raced his friends STi in my car. I will post the run in the mbworld kill stories tomorrow.Believe me it was a pleasant surprise.
Something to think about.
Keep up the good work. Let see how long it takes for you to get bored of your new found HP's.
Peace
Mario
BTW, which denos iridium spark plugs did you get, ik16? i bought some factory plugs from the dealer not too long agao and if the iridium is that much better i would also like to change mines out again.
Peace
Mario
