C32 Tire Pressure/Alignment Question
Old May 24, 2005 | 01:36 PM
alimo698's Avatar
Exclamation C32 Tire Pressure/Alignment Question
Hi guys, I have finally changed my stock rim(C32) to a set of 18" with 225/40/18 and 255/35/18. The car looks much more agressive and lower but when you sit inside, it seems to be higher off the ground... anyway, I am just wondering, do I need to do an alignment just from changing the wheel size (car is not lowered)? The shop said no, but the rear tire looks a bit funny, if you see it from the rear, the tire is slightly like this """ / body \ """ and from the dirt on the new tire treads, the outermost part of the tread ( ~ half a tread block, ~.5 inch) is not used. do you think i should get an alignment done or it's normal, as the size is changed for 245 to 255?
One last question, do I keep the same tire pressure as recommended, 32/35, or the heavy load 36/39, or some other combination? thanks a lot!
