ESP error
Old Jun 4, 2005 | 04:07 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
ESP error
well first i was driving yesterday and my car phone rang. same time i had an error that said that my left turn bulb is out. hmm so stop the car error went away, lights work. next day went to work no problems. then going home error came back left turn bulb out. went to the dealer bought new bulb. still didnt work. went on the mbworld to see if any one had this problem. someone said to clean the terminals. did it and after 4 times of pulling it out it started working. great! then i See a new error ESP program not available. I said WTF! drove the car around the block and pushed the ESP on/off a few times then shut of the car and restarted error gone! I'm not sure what going on with the car, drives fine. the only thing that was installed on the car was a timeport PSE with a MIkbox. not sure if this had anything to do with it. anyone with the same problem?
Old Jun 5, 2005 | 03:47 PM
Trekman's Avatar
is it because I took the battery off my esp came on and my sun roof started to act funny?
Old Jun 6, 2005 | 09:31 PM
Childish///AMG's Avatar
C32 AMG 2002, C 63 AMG 2009
I've had the "ESP error twice and each time it was only on for
alittle while. Took it to the shop and no problems were found
Old Jun 6, 2005 | 09:50 PM
amgdoc's Avatar
i think you are correct. if you take the battery off the esp error will pop up. you might need to resynchronize windows as well.
Old Jun 6, 2005 | 11:08 PM
Trekman's Avatar
cool thanks so much, It was like having gremlins on my car! hope mercedes benz fix this problem
Old Jun 7, 2005 | 12:06 AM
amgdoc's Avatar
forgot to add this:
but i think that since you did disconnect the battery you have to reset ESP steering angle sensor. This is done by turn the steering wheel all the way to left then all the way to right and then center. i think this is in the manual.
