Wheels On....
530Hp!!
Originally Posted by dragonAMG
Right at about 530 horsepower with the setup I'll be running.
How do keep tires on that beast (rhetorical question)??
Any pics of the engine? I love to see how he SC fits in the engine bay.
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Originally Posted by BuckeyeBenz
So you got 19/9.5 in the rears without lowering it....do you rub at all? They look sweet by the way!
Yes, they are 19's. 1.5" in the front and 2.5" in the back. I'm kinda thinking I could have went with 10" rear width's which would have allowed for a 3" lip. Shoulda woulda coulda... haha.
hmm, i have a 3" lip on my 9.5" rears. 10s dont get you any more lip at all on the C-class with HRE's.
Btw, looks awesome!
#33
so is that what my wheels look like? haha
and what he said....
Btw, looks awesome!
Btw, looks awesome!
#35
Btw, looks awesome!
Btw, looks awesome!
#36
im just curious why kleemann said not to lower it?
probably because it may ruin the suspension geometery of the car? Saying a car performs better when you lower it isn't really right. In some instances it can help, but not always. A lot of things need to be taken into account. This applies to all cars: When you lower a car, you reduce allowable suspension travel without putting the car on the bumpstops. Driving a car fast with bump steer sucks. bumpsteer=instant oversteer. In order to compensate for the smaller amount of suspension travel, you need stiffer springs. But stiffer springs will be outside of the compression and rebound range of the damper. So you then also need to replace those. And lowering the car effects the alignment. And from what little I know about the C class suspension, I believe camber is unadjustable in the rear. Which means when you lower the car, you are stuck with whatever new values the drop gives you.
I personally have not lowered my C32, but if you want to take performance seriously, and not just the bling factor, you need to consider a lot of things.
Matt
#38
I run Vogtland linear springs in the front only. It provides less understeer without having to add a rear anti-sway bar. Perhaps the lowering tip from Kleeman was regarding wheel clearance since he is running 19" x 8.5"s in front. BTW, I had Renntech springs all around with an H&R rear bar and the Vogtlands (front only) make the car perform better without over stressing the rear sub-frame. Just $.02.
#41
Originally Posted by Childish///AMG
We should have "Asked" Dragon to video-document his travels
#42
Originally Posted by JamE55
He is picking up the beast today as we speak and probably zooming down the fwy right now. Hopefully he'll have sometime to post some pics and vids of the monster!
#44
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Already did a few days ago!
