Power steering fluid reservoir
2012 GL550
Is the C32 power steering reservoir fluid in the same exact location as a C240?
http://www.installuniversity.com/mb/...uid_topoff.htm
It is the reservoir right below the driver side intake inlet tube, plain black reservoir. Same for C32 right?
The above link is the procedure for accessing the power steering fluid reservoir on a C240. It is the same on a C32 correct? Do our intake inlet tubes also just pull out? I know the one at the front grille just pulls off, but I never pulled off the other end connected to the airbox. Does that one just pull off as well without taking anything apart?
