C32 Wheel Offset
Old Aug 15, 2005 | 02:48 PM
5150_C32's Avatar
02 C32 AMG; 06 Subaru Legacy Wagon
C32 Wheel Offset
Hey guys,
I am looking at purchasing replica MB wheels that are 18x8.5 (all 4) with a 35mm offset. Will the fronts work without a 5mm spacer? Any advice would be greatly appreciated.
Old Aug 15, 2005 | 05:40 PM
andy_cyp's Avatar
Obsidian E55
Offsets
Originally Posted by 5150_C32
Hey guys,
You will have a very hard time getting reps to fit without spacers, and avoid spacers because you will have other problems later on.
The offsets for the oem 18" style IV AMG alloys are FR 37 REAR 34. Most replica wheels will not clear the front calipers due to there large diameters.
Be careful what you buy.
HTH
Old Aug 15, 2005 | 08:46 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
totally depends on the style of the wheel you want to get. replicas or not has nothing to do with it. i.e. my LM-6 replicas didn't need spacers with the 35 offset and the real LM-6 does need spacers.
you won't have any problem with hub centric spacers. Lorinser and Brabus both sell spacers to go with their rims that requires spacers for the C-class.
Old Aug 15, 2005 | 11:22 PM
5150_C32's Avatar
Thanks for the replies, I think I am going to pull the trigger on the rims....I have no problem running spacers, as I did on my M3 with the Big Brake Kit.
Frank what are the dimensions of your rims?
Old Aug 16, 2005 | 03:50 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Axis PHIN 19x8.5 19x9.5
i have 8mm Lorinser spacer + 3mm washer up front and 13mm spacer in the rear. the pic in the sig is before the rear spacer's put in.
