Trunk light not working, it's not the bulb, any other ideas?
Old Jan 5, 2006 | 04:25 PM
Expat's Avatar
2002 C32
Question Trunk light not working, it's not the bulb, any other ideas?
Well my warranty expired last week and now the trunk light's stopped working, it's not the bulb (it's intact but has 0v), any other ideas?
Why's my car so F*****g complex!
Old Jan 5, 2006 | 04:29 PM
Expat's Avatar
2002 C32
Looks like this might be the issue:
Replace control module
Any idea how much it's going to cost me?
Old Jan 5, 2006 | 05:29 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
trunklid lights can be switched on/off in the REAR SAM through stardiagnose...you might have a problem in the rear SAM.
greetingz,
Old Jan 6, 2006 | 11:49 AM
Expat's Avatar
2002 C32
The trunk light has started to work again so I'm off the hook
Old Jan 14, 2006 | 07:31 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Just in case.... here is the TSB:
Date: January 26, 2005
Order No.: P-B-54.21/133
Supersedes:
Group: 54
SUBJECT:
Model 203.040/061/064/065/076/081/084/261/264/281/284/740/747/764
Model 211.026/065/070/076/082/083/265/282/283
Trunk or Cargo Compartment Light Does Not Illuminate
If you receive customer reports in the above model vehicles that either the trunk or cargo compartment light does not illuminate and no fault codes are stored, the output transistor in the rear SAM may be defective. Proceed as follows to resolve.
1. Actuate luggage compartment illumination with SDS, if okay follow SDS guidelines to diagnose switch failure, if not okay proceed to step 2.
2. Check light bulbs, if not okay replace bulb(s), if okay proceed to step 3.
3. Check wiring harness for continuity with a DMM, if not okay repair or replace wire harness, if okay proceed to step 4.
4. Replace rear SAM and confirm correct functioning of illumination.
