What would be the downside of a bigger/aftermarker swaybar?
Old Jan 17, 2006 | 02:10 PM
Expat's Avatar
2002 C32
Question What would be the downside of a bigger/aftermarker swaybar?
I have a 2002 C32 and it's great but the body roll (especially on banked freeway on/off ramps) is starting to annoy me what would people recommend as a replacement sway bar (and how much) as otherwise the suspension is fine (for me) and what's the downside of a thicker/stiffer sway bar?
Old Jan 17, 2006 | 03:02 PM
TopGun32's Avatar
i had the same problem.... I think the springs are the way to go, to minimized the body roll.
If you have 17's, the ride would be almost 90% the same, but it will lower your front and reduce understeer.
Old Jan 17, 2006 | 03:06 PM
ClayJ's Avatar
ON PROBATION
Changing thickness/stiffness/effectiveness of either front or rear swaybar (or both) will affect the understeer/oversteer balance or tendencies of your car as well as affecting body roll/lean -- so picking the right one, and deciding to do front or rear or both is a part of the decision-making process in changing out swaybars.I have never owned a C32 - so don't have a recommendation for you. Hopefully someone else will chime-in with specifics.
Old Jan 17, 2006 | 03:42 PM
Expat's Avatar
2002 C32
Wouldn't springs effect the ride more than the body roll?
Old Jan 17, 2006 | 03:57 PM
ClayJ's Avatar
ON PROBATION
You are right about the swaybar being the way to go - just are going to have to get some valid information on which to change, and what to change to....
Old Jan 17, 2006 | 05:05 PM
mk2tmr2's Avatar
C32
They will affect either. If you increase the spring rates there will be less body roll.
Old Jan 17, 2006 | 08:01 PM
Blake P's Avatar
'09 A4 S Line
I have heard that H&R sways are a great product.
