Clearance issues with KW V2 install
MBworld Guru
white and whiter
Originally Posted by sdsilverm3
I can't wait either. The one look I had of the car while it was lowered temporarily with the wheels is really motivating me to make this work.
I liked the way the car looked and know this will be worth it in the end if it works out.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
32et w. a 5mm spacer ?
that is like 27et and wouldnt that push your tire way too far out to the fender?
the front was a pain in the *** for me too. i found the magic number to be 31et but your car does look pretty slammed which still might cause problems.
good luck man.
good luck man.
EVE
this is my car with KWV2s...
but I'm running Brabus MB VI's with their wheel specific spacers:
![](http://i16.photobucket.com/albums/b32/flipachu/IMG_6252_Medium.jpg)
It's just about less than a finger left in the front... I think I might even be able to lower it 1.5 more turns too.
flip
flip
Originally Posted by MBNorCal
what's the worst you can do? springs and shocks instead of coilovers?
good luck man.
good luck man.
Originally Posted by carolssoncclass
goodluck and hope you can solve the problem soon.
flip
flip
#32
eliminating the gap is dope. i used to do that for all the cars, but i find with the benz, its just too much hassle and causes more problems.
its bad enough that wheels have to deal with clearing the amg caliper and then the shock. i just wanted the best drop i can get, and it seems like 1 to 1.5 finger is about it.
your not crazy !!! i would love to tuck my wheels too, but tires cost a tad more for a benz then a honda.
#33
Okay, you guys are really going to think I'm
but here goes nothing.......
If none of this works I'm going to cut a coil off the top of the spring and move the seat up. Mwahahaha!
I know, I know! It sounds ghetto but it definitely would work. Of course this would be a last resort but it's definitely sounding more like it may happen the more I think about it.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![rice](https://mbworld.org/forums/images/smilies/rice.gif)
#34
Well...it's finally done! Had to raise the car up a little and shave the seat a little bit but no problems now. Thanks to everyone who helped out especially Shane from Harloff BMW and Joe from Group5 Motorsport. Here are some teaser pics for now. Supposed to be doing a photoshoot tomorrow with Dut's M3. Happy New Years everyone!
![](http://iiilgsrlll.com/Ling/car/Pics/c55/bbs/IMG_0242.jpg)
![](http://iiilgsrlll.com/Ling/car/Pics/c55/bbs/IMG_0244.jpg)
![](http://iiilgsrlll.com/Ling/car/Pics/c55/bbs/IMG_0246.jpg)
#35
2005 c230k
dude....! that turned out sweet. i can't wait to get my on - just order the h&r co's.
let me know if you know someone who can help me out with the LMs - price-wise.
congrats!!!! she looks sweet.
#36
that looks so clean !!! great job.
show some pics with dut's car when you get done. I used to drool over his M3.
Both yours and his are clean cars.
don't forget the flat emblem
#38
That is the perfect drop.
Damn you! I'm jealous now. I'm glad everything worked out. Can't wait to see the photoshoot pics
#41
Thanks for the compliments everyone. It turned out better than I expected. Just some minor issues left like minor rubbing in the rear. I'm pretty sure I need to have my fender rolled some more back there on both sides. Other than that the car rides great, better than stock. There is no more harshness.
I'll hit up my friend on Monday and see what he can do. Hopefully he can do what I told you.
The flat emblem and marker covers are on the way.
We need to do the photoshoot soon because his car is "sold" and will be picked up on Feb. 11th.
We did neither. We got it to work with the 5mm spacer (to clear the calipers) and no coils were cut. The clearance is scary close though. I still have about one inch of adjustability in the front but I'm sure I'll have issues with the springs if I go any lower.
Thanks Frank. It looks even lower when rolling. The back tucks pretty low hence the rubbing issues.
congrats!!!! she looks sweet.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Originally Posted by MBNorcal
did you end up cutting a coil from the top? did you still use that 10mm spacer?
congratz, that car is not HIGH in ride height at all!!! very nice looks perfect.
#45
2006 C350 Sport 6MT, 2000 BMW 323ci
so what did you end up doing to make the front drop and not rub?
#46
#47
We raised the perch up a tiny bit and shaved off a small section of the perch adjuster (1/8" if that). So far so good. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Btw, what is perch adjuster? I am getting coilover for my car soon too and I am just afraid I might come up with the same issue. Thanks for the help.
Nico
#48
Originally Posted by carlssoncclass
I am very glad to see ur project come up with an ideal outlook. Ur car look amazingly hot now! The ride height look perfect and the the LM look awesome.
Nico![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Nico
#49
Thanks.
The perch adjuster (seat) is the purple section that is circled in the series of pictures. You basically adjust that to set the ride height. What type of coilovers are you getting and how soon?
Nico
#50
MBworld Guru
white and whiter
Thanks for the help. I will most likely get the H&R coilover because the price is more friendly than the others. I thought of Bilstein pss9 as well but I'm sure those are a lot more expensive. It is nice to have damper adjustment those. How's the cornering on your car now? Once again, your c55 look awesome.
Nico
Nico
